Page 2 of 8 FirstFirst 12345678 LastLast
Results 14 to 26 of 93
    dukes of hazard
    Keep it simple to keep it cool!
    Sep 2011
    Northwest Louisiana
    We hit the button on job today, and as expected we had some problems. What we learned today is that you cannot use the existing butterfly valve, our placement of level sensor was wrong, the liquid feed to compressor was inadequate. We are going to remove butterfly and install 2 EXVs, pull liquid from old level sensor location into a liquid receiver to insure supply for compressors! Board failed on compressor! We will start mods tomorrow.
    A LITTLE BIT OF STUPID GOES A LONG WAY!
    May 2011
    NC Foothills
    I would like to see some pictures when it is finished and maybe some info on what you have done. We have done some conversions in the past with mixed results. The compressors in theory are great and in the right application they work well.
    Oct 2011
    La.
    Seems like a lot of work. Could you not have just replaced with a new unit, or is the unit in a bad spot? Sounds like costs could be getting rather high, time = money.
    I give it to you for taking the challenge. Keep up with the reports.
    Sep 2011
    Northwest Louisiana
    Equipment room severely restricted access. 12 weeks delivery on new chiller. This is best option to get bldg up before summer. Installing valves no big deal, ready to run by end of next week. Our call to use existing valves, bad call but we already have valves on job.
    May 2011
    NC Foothills
    Your not wrong about it being a lot of work but when the bugs are worked out it should be worth it. His customer should see a payback in energy savings if all goes well. If the compressors stay together as well.
    Sep 2011
    Northwest Louisiana
    We learned so much on this that we will cut down cost considerably on next one. Ex. We can prefab both headers and compressor mounts in shop and set on chiller as a unit. Our engineer has made drawings and we've made a lot notes. There is a lot of chillers that access has been restricted over years by other bldgs etc. We see a market for this until all such applications are either converted or replaced.
    Somewhere in the world.
    Its called design build engineering I actually use to work for a contractor years ago that use to purchase Large package Trane rooftop units and then modify the complete unit it was built for research labs totally custom engineering actuallly worked pretty good nothing wrong with thinking outside the box. And your right you are already started to identify problem areas that won't even be considered on the next machine first one is always the hardest next one will be easy and then the next one and so on stay focused.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Oct 2005
    that looks awesome . love the paint job. nice work
    RTFM!!!
    Sep 2011
    Northwest Louisiana
    We completed job last week, we believe it to be a major success for us, customer is pleased and wants to convert the YR sitting next to it this fall. It has created a lot of interest in engineering community, Ive attempted to attach a video complete with audio. I have a complete power point presentation I will share with anyone with email address in profile.
    Send it along my Brother.
    Windsor ON Canada
    I'd love a copy, thanks so very much.
    Jul 2005
    Southern California
    Please send me a copy also. Thanks in advance!
    Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
