Results 1 to 13 of 21
    Aug 2008
    San Clemente, CA
    Five things wrong with this water heater install
    1. So this must be the new way to vent hot flue gasses, NOT (not code).
    2. T&P 3/4" drain line has a flex connector of a smaller ID that can hold water on the back side of T&P valve (not code).
    3. No gas line sediment trap (not in compliance with National Fuel Gas Code).
    4. Missing safety pan, required when water can cause damage to structure (not code).
    5. Missing water pipe insulation on the two water lines on top of water heater (not code).
    6. No permit was pulled for this w/h change-out or the furnace for that mater.
    and she said a licensed plumber did the installation! So that somehow makes this job done right? Give me a break. I said you are lucky you are not dead yet. I didn't say that but implied it in so many words. At least she has a fire exchanger handy, may not get to it though.
    John
    Aug 2008
    San Clemente, CA
    This is the same house I posted this photo showing two aluminum wiring neutrals burning up. The entire house is wired with aluminum. So maybe the house will burn down before this other stuff ever gets corrected. I referred her to an electrician.
    May 2012
    Upper Michigan
    Shoot billy bob I knewd I needed a shorty!
    is that duct insulation fire proof? it sure looks to be in too close proximity, if not in contact with, the flues.
    the water pipe insulation, the stuff that comes with the heater itself, is a code requirement? is that just in your area or national code? it just gets tossed here and nothing ever said by inspector.
    is this a garage or what structure would be damaged?
    Aug 2008
    San Clemente, CA
    Code for the land of Fruits and Nuts (California)
    Is a garage. Wood platform and drywall would be damaged by water so it is code to set her in a safety pan with a drain line to garage floor.
    Fiberglass won't burn.
    Oct 2008
    Is that fire extinguisher placement gonna help them keep the imminent fire at bay?
    Aug 2008
    San Clemente, CA
    Well we added air conditioning and fixed the water heater venting so it vents! The plenum was interesting to build.
    Feb 2011
    Peoria, IL
    I take it the straps are earthquake proofing since your in CA?
    Quote Originally Posted by garychance View Post
    Yes, but not restricted to CA for earthquake concern.
    A portion of the area I work in requires them, but the majority does not. No mentionable quake in this area for decades.
    Feb 2011
    Peoria, IL
    Last few years in hospital work we are required to install seismic hangers on all trapeze hangers even here in the midwest
    Aug 2012
    NE wisconsin
    Better, but you've still got a power vented furnace and a naturally vented water heater sharing a flue.
    Aug 2008
    San Clemente, CA
    We learned that securing only the top of w/h allowed them to walk so code dictates two straps now.
    Fau has inducer fan for combustion gases not power vented, this combo venting is allowed.
    Oct 2011
    NJ
    Quote Originally Posted by JKopp View Post
    Did you fix the T&P relief? That fire extinguisher won't be much good if the water heater is flying through the roof.
