Results 1 to 8 of 8
    Is there a waiting period when turning on the breaker to the A/C?
    Well, the humidity is here. Is there a waiting period when flipping the power to the compressor? Thank you.
    Dec 2008
    Buffalo NY
    If you are warm turn it on.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Quote Originally Posted by qwerty hvac View Post
    LOL, thanks!
    SW Wisconsin
    All systems are different; some have compressor time delays after a shut down to provide the refrigerant system pressure time to equalize, allowing a restart without installed start kit capacitor assist.
    You could wait 5 minutes or, you could try it without delaying; the compressor, with some systems, will not be able to start until the refrigerant system requires a little more time to equalize.
    Some units have a heater for the compressor to boil off any liquid refrigerant that is sitting in the oil. Turning on the power 12 hours before using lets the heater do its job. But if it is warm out, not real critical.
    SW Wisconsin
    If you live in a climate where nights are rather cold then the compressor [U]should to have a crank-case heater component; by all means it is good practice to turn that breaker on to the condenser a few days or so before running the A/C.
    Therefore, as Baldloonie is indicating, if it starts up with liquid refrigerant in the compressor oil, the oil will be pumped throughout the system, insulating the evaporator coil & settling in low areas. This can also cause early compressor failures due to lack of oil lubrication. Therefore, a crankcase heater can be a very important component...
    Aug 2012
    My question is why are you turning the power off in the first place?
    It's not if your doing it right it's whether your doing the right thing that is important.
    Saint Joseph, MI
    Quote Originally Posted by toocoolforschool View Post
    +1, why was it turned off.
    No need to shut off the power or FWIM cover the unit up in winter time. In some areas with lots of trees, you might use a small cover just on the top. But full covers can actually trap in moisture and accelerate corrosion.
