Results 1 to 13 of 20
    Nov 2009
    Oakland County Mi
    CHHN Trane Screw Compressor Housing Leak
    Anyone know if this leak pictured is field repairable.
    it is.
    ottawa canada
    But .....it should only be done by a tech who has the experience and knowledge of the RTAA compressor . if done incorrectly you will be replacing the compressor .
    Buuuuut...you're right.
    Nov 2009
    Oakland County Mi
    is there a service bulletin on this anywhere? You two care to divulge any other information in regards to this repair?
    The Hot South
    Quote Originally Posted by Healey Nut View Post
    Agreed! And those compressors ain't cheap!
    Nov 2009
    Oakland County Mi
    i'm aware of the costs. any info would be helpful.
    Nov 2009
    Oakland County Mi
    I appreciate the replies fellas, I'd like for you to expand on those thoughts. I would like to be armed with a little explicit knowledge when I approach my boss and customer to justify the heavy costs associated with removal, factory rebuild and reinstallation. Thanks guys.
    Aug 2009
    Prattville, Alabama
    I'm not sure this even something to be concerned about. Are you basing your diagnosis of a leak on anything other than the presence of that oil? What do soap bubbles show? I believe Trane addressed oil marks on one type of their screw compressors (don't remember which one) as being a result of the assembly process, and not necessarily a leak.
    Nov 2009
    Oakland County Mi
    Not only does it leak, it leaks badly.
    Nov 2009
    Oakland County Mi
    Another thing, think this could result from frequent starts. I mean like 80000 per 8000hrs? I'm addressing that now.
    The Hot South
    No because when the circuit trips on 'low evap refrigerant temp' due to low charge, that is a manual reset alarm.
    Also, that compressor doesn't need to be removed and rebuilt. That oring can be replaced in the field and the only cost is the oring and a days labor (and misc shop supply's). Check with your local Trane office for a SB.
    Nov 2009
    Oakland County Mi
    That is not why it is short cycling.
