Page 26 of 26 FirstFirst ... 161920212223242526
Results 326 to 330 of 330
  1. #326
    May 2017
    I currently have SIGNAL running on a win95 OS with a HASP4 key, and I'm trying to install SIGNAL onto a XP machine. The problem there is the 5.0 software I have is a demo version and doesnt have the correct serial to link with the hasp key, so when i try to run it on xp i get the program is not enabled message
    My question is, is there some way to modify the reg file to change the serial, or am I just throwing my wishes down a well?
  2. #327
    California
    Quote Originally Posted by Glantz496 View Post
    It has to be at lease 18 years. But I recall if you simply delete the password file, your good. No key needed.
    Controls, the cause of... and solution to... all your HVAC problems.
  3. #328
    May 2017
    Quote Originally Posted by control$ View Post
    Which file name? Every time I remove the reg file it repopulates when I start setup
  4. #329
    California
    Like I said, I left Siebe in 2000. I don't recall the exact file name, but it was fairly easy to find. I never had a key on my laptop. Delete thd text and save the file.
  5. #330
    May 2017
    Is that file before or after install?
    I will have to look next time I am at the site.
    Thanks for the help
