Results 14 to 26 of 223
Thread: Network 8000 software
06-05-2007, 08:53 AM #14
- Dec 2005
- California
- 227
Forgot how great that 90's technology was. That little atari was great! Why the h*ll am I lugging around this Dell in y2k+7?
06-07-2007, 08:14 PM #15
- Oct 2006
- 133
check out www.richards-zeta.com for good B-C drivers
09-27-2007, 11:02 AM #16
New Guest
- Sep 2007
- 1
PSI software help, whose part number is LAPT-80800-PSI
Hello everyone,
I'm new here but already need some help.
I'm looking for a user manual for PSI software, whose part number is LAPT-80800-PSI.
Any help will be greatly appreciated.
Thanks.
09-11-2008, 12:28 PM #17
New Guest
- Sep 2008
- 1
Signal Software Manual
Our Barber Colman Specialist quit recently and we lost our Signal graphics PC.
I am looking for a manual for using and programming the graphic pages. Any help would be appreciated.
09-11-2008, 01:45 PM #18
- May 2008
- Fredericksburg,VA
- 6
PSI Programmers manual
I have available an extra PSI programmers manual for you HVAC Learner.
09-12-2008, 08:42 AM #19
- May 2008
- Fredericksburg,VA
- 6
You will need the Engineering version of PSI called XPSI ( extended PSI )
Part number LAPT-80800-EPS-I
09-12-2008, 08:54 AM #20
- May 2008
- Fredericksburg,VA
- 6
The EPSI version allows programming of all the blocks. It is called the Engineering version.
The PSI version doesn't allow programming but does allow changing of some, if only a few, block attributes. The PSI version is basically useless.
09-12-2008, 03:24 PM #21
- Jul 2001
- Canada
- 1,686
PSI ( LAPT 808000 ) software does the same as XPSI as far as being able to program with it , and having been using it since 1990. XPSI is a newer version with a few added tidbits.
The manuals are available and can be ordered on line, I have posted the link on other NETWORK 8000 threads. Operators manual is F-23058 ( gives only basics as far as what can be done , reason some think PSI is limited ) the programmers manual is F-23118
09-17-2008, 06:01 PM #22
- Aug 2008
- 10
MZ II programmers manual
Hi I was after a copy of F-23118, being in a similar position to mmkkww, have tried capUSA but they seem not to have it. Any other suggestions? Also I wanted to graphically represent the MZ II code, any suggestions re the best software and how to acquire. thanks Automate_it
10-10-2008, 07:32 AM #23
- Apr 2008
- Nevada
- 58
10-10-2008, 08:37 PM #24
- Aug 2008
- 10
Thanks for the help
Thanks for the help guys really appreciated
03-05-2009, 05:39 PM #25
- Mar 2009
- Oregon, USA
- 8
Programmers Manual
This thread is a little old but hopefully not dead. I also am in need of some sort of programmers manual for the xpsi software. I just inherited a system with a few problems. Any help would be appreciated.
Thank You,
Raqmenace
03-09-2009, 07:18 AM #26
- May 2008
- Fredericksburg,VA
- 6
Programmers manual
Did you need the psi programmers manual or an asd manual such as the microzone 2 programmers manual ?
