Page 1 of 25 1234567811 ... LastLast
Results 1 to 13 of 319
    Jan 2006
    Network 8000 software
    What software is required to make changes to Network 8000 controllres
    eg.MZ2-1 controllers
    Milwaukee Wisconsin
    If you are talking about the old Barber Colmans - PSI
    Jan 2006
    Correct it is the old Barber Coleman. Price book lists two part numbers
    LAPT-80800-EPSI
    LAPT-80800-PSI
    Milwaukee Wisconsin
    I have them - do you need them?
    Dec 2006
    What? Who? Where?
    What is the difference between EPSI and PSI?
    I have one of them, will have to check which one.
    kontrol out
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora http://www.youtube.com/watch?v=U7fjDS0jKiE
    Milwaukee Wisconsin
    Can't remember, Haven't used them in a while. However the 3 1/2" thick manual might tell me!
    Milwaukee Wisconsin
    motec, I can send you those files if you need them. My email address is in my profile. My distributer gave them to me free because he laughed when I told them I had several buidings with them. He couldn't believe they were still being used. It always amazes me how long some of our stuff holds up (or not).
    Last edited by HVAC Teacher; 03-01-2007 at 02:45 PM. Reason: unwanted urls automatically added
    Jul 2001
    Canada
    Lots of NETWORK 8000 still working away , first NW8000 controllers I put in back in 1986 are still running today. EPSI-1 is the extended version of PSI
    Feb 2007
    Sacramento, CA
    What are you changing? The programming in the GCM/LCM's or in the ASD devices. You can use Hyperterminal to get into a GCM or LCM & modify it's programming. You really only need PSI if you are going to modify the programming in Microzones, PEM's or Microflo's.
    Jan 2006
    Thanks for the reply. Yes to all, as I may have to modify the asd controls.
    When connecting to the GCM or LCM with hyper terminal are you connecting
    to the the 25 pin connection as a direct connect?
    Feb 2007
    Sacramento, CA
    Yes, connect to the 25 pin connection. You may have to change the port switch for connection setting, it depends on your cable.
    Feb 2007
    Recently had a system 8000 dumped in my lap. Can't see a thing and very little is working. The rep left an Atari Portfolio with the interface and no more.
    There is no chance they will show up to check the system out, but they will upgrade (of course !!).System has Microzone II controllers bussed together. Help!!!!
    Jul 2001
    Canada
    The ATARI's worked fairly well to access the NETWORK 8000 systems , BARBER COLMAN did not promote them very long, I think I still have the manual on it around here someplace.
