Results 1 to 11 of 11
    May 2013
    LG Mini split LA090HSV2 fan runs all the time
    I have a LG Art Cool Mirror 1 ton. I just turned it on for the season. The fan never stops running I notice but the compressor does.
    This was installed last year to cool a large upstairs room. The room has 2 AC vents from the Central Unit but in Texas during summer the upstairs needs help. It's a pretty big room. I don't mind the fan running per-se' because the LG unit is on the opposite end of the the room from the vents and the stairwell. So it pulls air across the room when cold air from the vents would tend to just drop down the stairwell.
    Still... is it supposed to operate that way? The manual for these units are not very good. Or is the fan supposed to turn off when the compressor does like my central unit does.
    This compressor has the inverter technology which I think means the compressor operates at multi speeds. Maybe the running fan is part of that?
    Thank you for your help.
    Can't say about LG for sure but most minis do run the fan constantly.
    Sent from my HTC VLE_U using Tapatalk 2
    May 2013
    Thanks BaldLoonie. I wish the manual was a bit better about explaining how these things work.
    The mini splits are new in my neck of the woods. My long time AC man knew nothing about them and I think I was the first for my contractor.
    which fan are you talking about, inside or outside?
    how do you know the compressor is off?
    Arizona
    As does LG!
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    I don't know LG that well, but most mini splits can be set to only run when cooling or heating is needed, but the default setting is virtually always for the fan to be running.
    The air temperature sensor they use for control is in the air handler, so if you have it set so the fan turns off, it can/will affect the temperature swing in the room, and the cycling of the unit.
    May 2013
    Quote Originally Posted by pacnw View Post
    The inside fan. I went out and checked the compressor. I didn't see any movement or feel any vibration.
    May 2013
    Thanks JimJ and Mark. Appreciate it.
    I will have to replace my main carrier SR 22 unit in the near future. It is 5 tons. Hopefully, I will downsize that a bit with a separate unit upstairs. Rough estimate on sq footage says maybe 3.5 tons although my ceilings are 10 ft instead of 8.
    Jun 2010
    Additional infractions may result in loss of posting privileges.
    peanut2004
    Jun 2010
    peanut2004
    Done, Sorry and Thanks
