    Feb 2007
    minimum outside temp for ac
    Our buyers have an ac guy coming tomorrow to test our a/c.
    My question - is there a minimum temperature that the outside air temp needs to be to startup the system? Its warming up, but still pretty cold here in Pittsburgh. I do not want to have damaged caused by any testing.
    Doug
    Nov 2005
    It would all depend on what type of system you have in regards to what type of controls you have on the outside unit.
    Kentucky, Michigan, Ohio, Arizona, Colorado, Nevada, and Califormia
    In most cases, the answer is no. Most manufacturers' charging charts start in the 60's. Barring low ambient controls, variable or dual stage systems, and/or commercial applications, now is not a good barometer for ac performance.
    "Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
    Clark Griswold
    Mar 2006
    use search link, had this discussion last spring.
    Anything worth doing, is worth doing right......the first time!!!
