Results 1 to 13 of 25
    Oct 2009
    Mukwonago, WI
    How'd you like to change a compressor on this thing???
    5 stories up... The unit was installed like 4 months ago, job isn't done yet. I'm hoping the inspector says something. 20$ says the ductwork isn't r-8 either.
Size:  30.6 KBName:  20130507_125922.jpg
Size:  60.9 KBName:  20130507_130023.jpg
    Dec 2008
    Buffalo NY
    The ductwork looks nice. I just don't understand why it was not installed on the lower roof. Looks like there is nothing on it.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Sep 2012
    .... Is the disconnect hanging over empty space like I think it is????
    SE Michigan
    Not code around here...no guard rails.
    Tallahassee, FL
    That's nuts! But nice at the same time :/
    That is one of the the nicest looking disgusting monstrosities I've ever seen.
    Jul 2009
    Michigan
    There is a wooden guard-rail, it's on the lower deck. Would you believe that whoever installed it never plans on servicing it?!
    Atlanta GA area
    I am sure there is a reason the unit is not on the lower deck... however a lot of $$$ went into putting it up there...
    I suspect an inspector will have lots of fun with that install.
    GA-HVAC-Tech
    don't let OSHA catch you working on that thing
    Dec 2010
    Woodbridge Twp, NJ
    Quote Originally Posted by coolwhip View Post
    The guardrails are on the lift you need to service it
    Every customer you take for granted today will be someone else's tomorrow.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by DLZ Dan View Post
    So true.
    Imagine trying to wash the condenser???
    No heat gain on all that sheet metal
    Yakima, WA
    Quote Originally Posted by retube View Post
    The phrase is usually: "That's SERVICE'S problem!"
