Results 1 to 13 of 29
    Can blower wheel work when installed backwards
    On service call, high limit keeps cutting out after about 10 minutes , looks like blower wheel might be installed backwards, but the locking nut is on the oposite side of the motor and I can not see or feel the motor side to see if it has 2 locking nuts, although I have never seen one with 2 ,but there is lots of things that I have not seen ,but they exist
    I would think that if it was installed backwards that it would not run that long before tripping high limit, any body run into similar situation??????
    Sep 2006
    erwin nc
    if you have cw wheel on ccw housing then yes it would trip high limit, also check the size of wheel, i came across one where someone had installed wrong diameter, the only way i found problem so soon is because they left old wheel in bushes beside unit. hope this helps
    Yes that helps, Refresh my memory , you determine cw or ccw by looking at motor from shaft end, correct?
    Is it possible to turn wheel around, or must it be replaced, I am thinking replace ???
    May 2003
    Dixie
    no there is another way.....hint..it's in the yellow pages
    It is time for all good men to come to the aid of their country, for we are in deep crap.
    Florida
    Quote Originally Posted by frigetater View Post
    Much easier too.......
    Milwaukee Wisconsin
    you are correct - looking at the shaft
    EASY frig and smoken, and thanks teacher.
    I guess some of these guys forget when they just got in the business, or were they just born with all the correct answers.
    May 2003
    Dixie
    IF you're in the business..get the pro status and you'll get all the help you need..if not you are messing with dangerous equipment
    I am, I have just now had enough posts to qualify for pro forum,
    I would uderstand your deep hearted concern if this were electrical issue.
    Easy frig, this is not rocket science, just not came accross this before.
    feal free to quiz me on something complicated if you think I am a HO.
    Houston,Tx.
    Quote Originally Posted by Infohunter88 View Post
    Not trying to add fuel to the fire here, but even a real new tech should be able to just look at the blower wheel and determine in 30 seconds or less if the thing is turning or installed the wrong way.
    oopps, it took me 31 seconds, I guess I am a real winner huh, I know your type. hehehehehehehehe
    burlington county n.j.
    could be wrong blower wheel, could be reversed motor.
    need to look at housing to see which one.
    thanks for the input, it turned out to be wrong wheel, Motor was original and correct rotation
    looking at them side by side it became clear, I never forget this one, thanks all....
    It is fun to cut up a little on this forum, hehehehehehehe
