Results 1 to 13 of 14
    Mar 2013
    swan valley idaho
    clevland combi oven
    m#ogs1020
    intermitently getting the eo1.1 error message for low water pressure according to manual. I was thinking water circuit scaled up /plugged up. noticed on top of oven it says "no descaler" carved into unit? I guess you can't use de-scaler on this model? doesn't make sense. anybody ever work through this error message? should i be checking water solenoid inlets,plugged inlet to pressure sense? any ideas?
    this thing is definetly intimidating-wholy controls
    Oct 2008
    I didn't see a E1.1 in the manual. I found E1.0, which says:
    Tap closed
    Solenoid valve Y4 faulty
    Pressure switch S1 defective
    Dirt filter in the solenoid valve or in the mains water connection dirty
    T-piece for pressure switch / manometer orinjection nozzle in water supply blocked / dirty>clean with needle
    Contact problems between pressure switch andterminal strip X15 of the control module
    Appliance not connected to soft water and thereforeinlet calcified
    The manual also has instructions for descaling using Cleveland's "Dissolve" descaler beginning on page 25 of the service manual.
    You're correct on the intimidation factor. These things are very complicated - much like the Rational combi ovens I DO see allot of where I work. The Cleveland Convotherms were a rare unit when I did my TWO training courses on them. I worked on exactly ONE in the three or four years they have been out there.
    You're also correct in considering scale to be a factor. Those things need to be descaled MONTHLY per the manual. However, if incoming water quality is bad, you might want to find those components delineated in the error code translation, disconnect and inspect for any blockage. The parts manual on partstown.com actually identifies an orifice at the regulator assembly to meter water flow.
    You could have poor water flow due to a filter needing changed, a blockage such as sediment in a valve's strainer screen, a failing water control valve or a faulty pressure sensor.
    With my lack of actual experience on the Convotherm, that's all I can offer you.
    Mar 2013
    swan valley idaho
    i agree with de-scale, but for some reason on top the oven in cut out steel letters it says" no descaler" where the manual says to add? it's like a raised bracket with the lettering cut out so you can't miss it, right where you would add?
    Oct 2008
    Maybe someone eliminated the port on top - for whatever reason I don't know - so now you have to take the side panel off and add the descaler directly. You never know what who did before you - and why.
    Cleveland always liked to put the descale port for their steamers on TOP. I work at a resort now with a fleet of Rationals. They have some knuckleheaded ways to put in their descaler too. On their newer SCC line, you gotta have a pump (which they sell you) for putting in descaler. Otherwise - side cover comes off, probes come out and you pour it in with a funnel.
    Mar 2013
    swan valley idaho
    ya- i see they have some sort of automatic chemical injection. i wander if the chem company added the labeling. it looked pretty legit, cut out in stainless, saying "no descaler" right where you would add it. I'll ask clevland if there is some reason this model can't use de-scaler, but that just don't sound right?
    Oct 2008
    Yup....calling them is your best bet. They may have designed in a reservoir with some descaler delivery system such as an "eductor" that Groen uses on THEIR combis. If you happen to speak with Jack Muzzio @ Cleveland, pick his brain. He may be a little brusk with you, but he knows his stuff.
    Oct 2008
    Well crud... I do VAGUELY recall that Cleveland did have an automatic dispense system for those ovens. However, I DON'T recall whether that included boiler descaling or if that was just the their ellaborate "sprinkler" like oven cleaning system.
    I actually searched for my training manual, but it's buried somewhere in my garage.
    Anyhow, I hope it proves to be an easy fix...
    Nov 2009
    sudbury on, can
    Ive worked on these off and on, all those things ECTofix said need to be checked. As far as the descaling, most of the units i work on are boilerless, are you sure it has a boiler to descale? The low water pressure error is for the injector(some call it a spritzer) that sprays water into the oven on the element or heat exchanger if it is gas to make the steam.
    Mar 2013
    swan valley idaho
    thanks. it is gas. should i then be checking the orifice at the spritzer nozzle then too? is that the orifice they are mentioning? And i'm assuming the main inlet water soleniod would be the one with the filter screen to check? thanks
    Nov 2009
    sudbury on, can
    Quote Originally Posted by kklobas View Post
    hello, the error is coming from the pressure switch failing to close, look for a blockage at the screen at the triple solonoid inlet. I think you said this was an oes model, that should be a spritzer unit. The pressure switch is mounted on the regulator assy for the water injection. There is also a pressure gauge on it, if you could watch this gauge during operation , you could see if its maintaining the minimun pressure and you would know where to look and would know if you have a bad pressure switch. I may be wrong about this, but I think its 20 psi. I have also seen filter cartridges plugged up so bad there is no pressure to the unit, I would check for that first.
    Hope this helps
    Mar 2013
    swan valley idaho
    thanks. its an ogs model. looks like regulator assembly with orifice and switch is just after 3 way solenoid. ill check filter, that inlet, and orifice/switch for blockage. Is it pretty normal to need to remove and clean low/high water probes also? althogh it sounds like they have nothing to do with this error, they should probably be cleaned as well i would think. Hopefully i'll be looking at this tomorrow. thanks for suggestions.
    Nov 2009
    sudbury on, can
    Im not sure what you mean by low and high water probes? I actually looked at a unit today for the same error, intermittent low water pressure . eo1.1. So the pressure gauge on the regulator assy was just below 15 psi when the solonoid is actiavted to make steam. I called Garland, those pressure switches will open below 15. They should be set between 17 and 20. I adjusted the regulator to 20. Im thinking it was set right at borderline and thats why failing intermittent. Watching that pressure gauge during operation will tell you a lot.
    Let me know how you make out, its funny the exact same thing has happened to me.
    Mar 2013
    swan valley idaho
    thanks for info. haven't been back to oven yet. clevland did say it sets error at 15psi. so i was also thinking to watch gauge, make sure nothing else is on water line, clean inlet solenoid screen. i think a setting of 20 sounds like a great idea
