Page 9 of 17 FirstFirst ... 2345678910111213141516 ... LastLast
Results 105 to 117 of 213
  1. #105
    Jun 2013
    Quote Originally Posted by Joehvac25 View Post
    This is off topic but what ever became off hillmor
    Buddy of mine just got them. They look cool. But he already broke the hook off the back and said something about having to send them back. All this after a few days of owning them.
    Sent from my iPhone using Tapatalk 2
  2. #106
    In a machine room
    Quote Originally Posted by TNtaco View Post
    Sounds like another one designed for the padded case......
    Worry is a really gross misuse of one's imagination. -- PHM
  3. #107
    May 2012
    Upper Michigan
    Quote Originally Posted by chuckcrj View Post
    Might as well have hose ports on the box too, when you need a reading quickly open the box, but shut it before anything falls apart
  4. #108
    Aug 2009
    Maine
    Ne design concept. Quick get a patent.
  5. #109
    Houston, TX, USA
    Well I like the case to protect expensive tools. I liked it in my first generation digimon which I still have. And my testo 550 also came in the case, which I like since storage is simple. The sman3 I have not used yet cause I need a case for them. I don't like the huge case that field piece offers. I prefer the size of the digimon and testo case. I have a truck so I store my testo and digimon on my tool box in the bed. That way they are out of sight. The sman3 are still in the box at home till I find a case that I can fit them in.
  6. #110
    Aug 2009
    Maine
    Don't think my 570 or the Sman4 will ever see the inside of a case. My analogs didn't, and the digitals are suppose to make my life easier. If they break, then I expect all will hear me bi*ching about them, but I so no reason to baby them. The last set of Imperials that I bought weren't exactly cheap either.
    Quote Originally Posted by caddy View Post
  7. #111
    Nov 2011
    East Side
    Quote Originally Posted by Brent Ridley View Post
    71Chops,
    Maybe your right. I was just so disappointed in the answer that was given from the VP. I guess it kinda rubbed me the wrong way. I myself have owned or do own several sets of digital gauges from several different manufacturers all the way back to the first gen Testo 523's. I've always received great customer service and that response just sent me for a loop.
    I guess it makes no sense pointing out the obvious and I'll just shut up until Mark posts his review maybe then we can have a good discussion.
    I completely understand where you're coming from. you get invested in something, then expect the same investment from the supplier/manufacturer. The beauty of this field of work is that talk means nothing......results mean everything. we can talk ourselves blue in the face with any number of a thousand issues....in the end, the results need no words.
  8. #112
    Jun 2009
    South Carolina
    Guy at work has a set of hilmors. He only uses them on new start ups. not troubleshooting.
    But our supplier said use it for a couple months if you dont like it he can switch it out for the sman4.
    thought that was pretty good offer
  9. #113
    In a machine room
    Do you take the hoses off to put them in the case?
    If you want them in the case that's fine. But most guys don't like stuffing gauges and hoses in a case after every call, much easier to grab them off the rack they are hanging on and go.
    If digital gauges should go in a case then analog should for sure! Analog gauges are not all that accurate new, let alone after they have bounced around in the back of a van for a week.
  10. #114
    Houston, TX, USA
    Yes I take the hoses off and place the caps back on my 550s. Then hoses and testos stay in same case. It only takes about 1 min to put hoses back on so I don't see how you save so much time. To me its not how fast u get in and out of a service call,but that u properly diagnose and repair it the first time.
    Not every tech on the field takes care of their tools the same. I like my tools looking clean and in like new condition.
  11. #115
    Sep 2006
    Burnaby, BC
    How many cases of AA batteries do you go through a month with those though?
    None. I converted it to Lithium Polymer right away. $20 for two batteries that run the gauges for 24 hrs at a time and take one hr to charge.
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
  12. #116
    Feb 2012
    Toronto Canada
    So MR VP you got yourself a digital gauge Expert a set to review. How about a digital rookie review. To see if someone going digital for the first time can pick them up easily.
    Maybe say in a harsh environment like Canada .........Maybe
    What gauges are we even talking about?
  13. #117
    Dec 2011
    Australia
    The user manual for the digimon sc gives instructions that the manifoldSHOULD not be used in the rain.
    Im not sure if it can be used in the rain?
    What happens if it blows up from water damage?
    Is it still covered by warranty?
