Results 1 to 8 of 8
Thread: York 80 furnace
    Feb 2007
    York 80 furnace
    I have a York 80 home heating system thats 6 years old. This year I've had a nonstop problem with the unit. When the thermostat calls for heat, the pressure switch goes on and the ignitor lights for about 8 - 15 seconds but the flames don't go on. Initially I was told that it was a flame sensor problem. So the tech replaced it and told me that all was fine. He told me that in the future, if this occurs again, just remove the flame sensor, clean off the metal prong with a soft steel wool and put it back. This was back in January. Every other day since January, I've had to remove the flame sensor, clean it and pur it back so that the unit's flames will go on. Could anyone give me their thoughts on this problem. Could this be a control board problem. The furnace is located on the second floor of a 3 story house on ceramic floors.
    does the furnace have a good ground?
    does the furnace have a good ground? Where in your house is this furance located - on the second floor, on a wooden floor? Or is it in the basement, siting on concrete floor?
    Feb 2007
    Help for my York 80 furnace
    just for an experiment....
    just for an experiment, run a separate ground wire to the furnace temporarily. Could be the culprit. Run it to a known solid ground ... copper plumbing pipe, etc.
    Feb 2007
    va
    in addition it may be worthy to check the wire from the flame sensor and the connections.
    vaughn
    Outside Houston, TX
    Don't think its flame sensor related if descricption in post is accurate (ignitor activates, no flame). Could be board related, could be several things. You need to get the contractor back out.
    Grottoes VA
    Maybe you need to find a good contractor.
    Hint* Don't hire the cheapest contractor.
    You need another service tech.
