Results 1 to 13 of 34
    Feb 2007
    conduit some form of wireloom for compressor power line?
    Just trying to get some things solved now that I found this helpful forum.
    I have a bright orange power line coming from my break box that runs to my ac unit, its the only orange power line in the breaker box. All the other lines are inside a pvc? pipe coming out of the breaker box but the orange compressor line is not. It sticks out like a sore thumb in my kitchen and runs about 3 feet before it goes into the ceiling.
    Is there any way I can cover or hide this wire WITHOUT taking the line out of the breaker box, I'm not good at that stuff and don't really know how to do that stuff.
    THanks in advance
    ryan
    Quote Originally Posted by eliteconcept View Post
    THanks in advance
    ryan
    take a picture and post it if you can
    Before you criticize someone, walk a mile in their shoes...that way you are a mile from them and have their shoes
    Feb 2007
    here is the line from the breaker box
    Jun 2006
    Las Vegas,NV
    Call an Electrician out is your best bet!!
    Oregon
    That orange line doesn't like it's up to code since it's exposed wiring in a living area. However the other conduit doesn't look like it's up to code either since it doesn't look connected to the breaker box and it doesn't completely go up into the ceiling.
    I'd get an electrician out to do it right. I can't imagine it would be all that labor intensive.
    P.S. is that conduit pipe even attached to anything?? It sure doesn't look like it.
    Feb 2007
    the pipe from the breaker box is not attached to anything.
    I assume this is also an issue where the line comes down from the ceiling in my utility room and snakes along the wall,floor to the outside wall where it is in conduit.
    Huntsville,AL
    room a/c?
    just paint it for the moment --
    BUT, it is not right & you need an electrician to properly install this line so someone does not get electrocuted.
    Feb 2007
    the power from breaker snakes along the floor/wall in the utility room. I am going to find someone to put conduit around it and fix the lines from the breaker box.
    Jan 2003
    You have been hacked....
    Feb 2007
    you have been hacked? what?
    Grand Rapids, MI
    hacked = a term for poor quality workmanship. dan
    MA
    yeah, take a look at the wall o' shame if u need further description...
    thats too bad someone took atvantage of you
    orange wire looks like romax just sheild it with pvc you'll be ok if that is romax
