Results 1 to 7 of 7
Thread: Dust in home
    Feb 2012
    Tyler, Tx
    Dust in home
    I have residential HVAC customers complaining of dust in their home. Other than filtration what steps can I take to diagnose the cause and source of a constant dust issue. After cleaning the duct the source of the dust has to be outside of a mechanical issue. I'm just looking for some advice from someone who may have better knowledge of this type of issue. THanks
    May 2013
    What kind of air conditioning system has been installed there?
    Athens, Ohio
    First seal the duct system, especially the return. Pay particular attention to building cavities that are used for returns.
    Then determine whether the house has a positive or negative pressure and advise them to seal leaks which can pull in dirt.
    Feb 2013
    Yes, did you seal the duct system? I know in my experience this can often times happen because there are leaks somewhere that is pulling in access dirt into their house.
    Arizona
    Quote Originally Posted by kdean1 View Post
    I agree with all of the above, but if major supply duct leakage remains after sealing the returns you can create some large infiltration and safety issues . Deal with these before doing air sealing of the home and always do a CAZ test after any kind of this type of repair!
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Supply leaks make the house suck.
    Return leaks make the house blow.
    Fancy air filters for the HVAC system do nothing to reduce visible dust in the house.
    Cleaning ducts does nothing to reduce dust in the house.
    May 2013
    In other words, seal up the supply. It's a thin line because on one hand you want your house to breathe, but not so much so that a lot of particulates get in.
