Results 1 to 11 of 11
    Oct 2012
    arlington, tx
    Sil-Fos = amount of joints
    Would Anyone know or have anything that would tell you what the expected amount of joints per size of pipe a pound of sil-fos can do?
    Jul 2012
    Western KY
    I would say it depends on the man with the torch.
    Feb 2011
    Peoria, IL
    This is probably no help, but i was always told with solder, if its a 3/4" joint it takes, 3/4" of solder. (i use more silflos then that i can say that for sure)
    Apr 2003
    Maple Grove, MN
    It definitely depends on the person doing the brazing. You can use as little as an inch, or as much as an entire stick on the same joint, depending on your technique, the cleanliness of the joint, and the percentage of silver in the rod. I would say I tend to use more than other techs, because I try hard to get the rod to get sucked into the joint, and then I try to slowly build a cap on top of that on almost all of the joints that I do. I also don't clean most of my joints, so I try to make up for it by using extra sil-foss.
    If you take the time to properly prep all of the joints, and have a good technique, you can get away with using less rod, and cheaper rod (less silver).
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by justinkarma View Post
    Here's a guide from J.W.Harris with some info on how much material to expect per joint. (See p.13)
    GuidetoBrazingandSoldering.pdf
    Feb 2007
    milford ct
    Quote Originally Posted by garychance View Post
    that's what i was taught also
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
    Oct 2011
    Chicagoland Area
    If you're trying to figure out a way to save money, I would look elsewhere.
    Aug 2012
    west burbs,il
    I agree with sac, just keep enough stocked on the truck.
    Salem, WI US
    Some joints are in a very bad location you have to keep heating and filling Silfos until you are satisfied, pretty much what ever it takes.......
    Betabass
    Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome.
    Newnan Ga,
    A pound of sil-foss is comparable to 66 7/8 welds straight out or 73 5/8 welds straight or 93 3/8 welds typical.... is 43 7/8 welds and 52 5/8 welds....
    Capping or topping uses about 15% more
    Oct 2012
    arlington, tx
    Purpose of this question wasn't really to try to save money. (but who isn't?) it was really for my to make sure that I wouldn't end up screwing myself in bidding some of these bigger jobs that might take 20lb to 30lb of sil-fos. that could end up in a big cost to me. I'm sort of new at the commercial estimating and trying to prevent a problem before I have one. Thank you all with all the help with this! It's nice to see a forum community to come together so well. i have been on others for my classic car questions and its like polling teeth for help sometimes lol.
