Results 1 to 11 of 11
    hydronic system with a vent on the roof
    hi everyone
    i recently ran in to a hydronic system with a open vent on the roof.
    the customer's complainting the system is losing water every couple days.
    on the top floor there's a container with a site glass and vent to the roof.
    does anybody have a solution for this problem?
    Is that a steam system? If it is it is an old one pipe with a condenser box. best to call one of the Dead Men who used to install those systems. OR has it been converted from steam to hot water?
    Nov 2000
    Upstate, SC
    Need more information. As hvac1000 asked, is it a steam or hot water system? Does it have a make-up water valve and is it manual or automatic? Does the vent to the roof tie directly to the container with the sight glass?
    Bobby
    Dec 2001
    Southern Tier, NY
    itsa gravity system
    so find the leak
    Lancaster PA
    Use to see alot of those systems.
    Its hot water.
    The vent on the roof isn't the problem.
    As Slim said, you have a leak some where.
    Check inside the boiler, see if the combustion chamber is wet.
    Jan 2003
    Kansas City
    Great link for this problem. Like I said in my other post (get a dead man to fix it. ) :>)
    Quote Originally Posted by slimwoodie View Post
    itsa gravity system
    so find the leak
    but the thing is, that the newer boiler has a circulator pump.
    is it still consider a gravity system.
    should the vent be cap off. because who ever change out the old boiler, added a expansion tank at the boiler too.
    manitowoc wisconsin
    Quote Originally Posted by deon1116 View Post
    The old expansion tank & vent should have been completely removed from the system.The installers of the new boiler goofed.
    Take your time & do it right!
    Lancaster PA
    Its not gravity anymore.
    The vent should be capped off.
    thank for the help everyone.
