Results 14 to 19 of 19
    Oct 2012
    Ohio
    So when you go to take them off, you dont need to seat the king valve. You just close the ball valve and take them off?
    Dec 2008
    Buffalo NY
Size:  41.8 KBName:  ImageUploadedByTapatalk1368482049.626676.jpg
Size:  37.3 KBName:  ImageUploadedByTapatalk1368482062.229830.jpg
Size:  41.0 KBName:  ImageUploadedByTapatalk1368482073.217041.jpg
    Here are pics of mine.
    Sent from my iPhone 4s
    using Tapatalk
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Dec 2008
    Buffalo NY
    Quote Originally Posted by Musick94 View Post
    You would still need to close any valve on the machine to the access port. But you close the valve on your hose to contain the refrigerant in it.
    Sent from my iPad using Tapatalk HD
    Oct 2012
    Ohio
    Oh okay, that makes more sense now. Thanks for all the helpful information!
    Dec 2008
    Buffalo NY
    No problem.
    Jan 2011
    Ottawa, Canada
    While we are at it.. May I ask the proper way to purge the lines when switching refers?
    I believe that you ensure that the refer is drawn through hi to low hoses into suction line. Then remove and open gauges and manifold to atmosphere.
    Then when hooking up to new system with different refer, purge the manifold and lines with the new refer at the manifold connection? What about the yellow/middle hose? I want to ensure that I am not mixing refers. Also what is the best way to purge N2 through them? Just flow it through one hose and open the manifold and ball valves? Does anyone ever do that?
    Thanks.
    Sent from my GSIII on Tapatalk
