Results 1 to 13 of 19
    Oct 2012
    Ohio
    Multiple gauges?
    I'm pretty new to the field. I have about 1 year of experience and I'm in school. I've heard a lot about oils getting mixed up in gauges. I have one pair of gauges so far, but I'm thinking about getting another set for 410a. I do mostly residential work. Who here uses multiple sets or one set?
    Jan 2010
    If your up for a second gauge, make it digital.
    I have & use multiple sets of gauges, It's NOT because of a concern for oil in the hoses; if you have more than one compressor in a machine-you had better have gauges on EVERY one of them.
    Once again-if you are getting extrodinary amounts of oil, you have bigger concerns than contaminating the next piece of equipment.
    Oct 2012
    Ohio
    That's a good point. Had not thought of that one.
    Apr 2012
    Louisiana
    Two sets of manifolds will probably be all you will need doing residential. Plus you have a backup on hand if you break a gauge.
    Oct 2012
    Ohio
    That's what I thought, I do some commercial. But not enough to get more than 2 sets. Saw an older set at a flea market for $35 the other day so I'll probably get that and eventually some low loss fittings.
    Oct 2010
    Quote Originally Posted by Musick94 View Post
    I like the ball valve hoses rather than low loss.
    Oct 2012
    Ohio
    What are the ball valve hoses used for exactly?
    Dec 2008
    Buffalo NY
    So when you disconnect your hoses refrigerant doesn't blow in your face. Also they are great for closing off the hoses so you can draw the refrigerant back into to the unit before you disconnect the gauges.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Oct 2010
    Quote Originally Posted by qwerty hvac View Post
    ^^^ what he said. Keeps you from freeze burning your finger too bad.
    Oct 2012
    Ohio
    Oh okay, sounds like a good investment. Wouldn't you really only need one for the liquid line?
    Dec 2008
    Buffalo NY
    I like having all three.
    Oct 2012
    Ohio
    This is probably a dumb question, but when I looked them up I saw shut-off valve and ball valve hoses. Is there a difference between the two?
