Results 1 to 13 of 32
    May 2013
    Confused R-22 Chiller retrofit
    Does anyone know an approved Refrigerant for R-22 Chillers? More specific those with flooded evaps. All the ones i have seen have too much glide Honeywell says Ill get back to ya ? yikes Guess we wernt ready for this after all
    Their are a lot of threads on retrifit refrigerants but manufactures don't back them unless its nordine shipped with poly oil. As for chillers why don't you just stick with r-22?
    East of big city prices.
    Yes you are going to be hard pressed to find an alternative for flooded applications I just don't see it happening .
  4. Likes CHILLERSVCMAN liked this post
  5. #4
    May 2009
    Bardstown, KY
    R438A
    Why convert? Well, with the rising cost of R-22, and this being about half the price of 22, the competition is retrofitting and winning bids. So, that's one reason.
    Attached Files Attached Files
  6. #5
    Jul 2000
    Cuenca, Azuay, EC
    I've read where R404A and R507 have been used for flooded systems. Performance-wise, they're both fairly close to R22.
    R404A has a very low glide and R507 has a zero glide, being a 50/50 blend of R125 and R143a.
  7. #6
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by mark_ballard View Post
    Any links relating to chillers with flooded evaporators?
  8. #7
    Aug 2009
    Prattville, Alabama
    [QUOTE=icemeister;15754611]I've read where R404A and R507 have been used for flooded systems.
    QUOTE]
    Any links?
  9. #8
    Jan 2011
    Central PA
    I hae not used it but it looks like R421A glide is better than MO99
  10. #9
    Jul 2000
    Cuenca, Azuay, EC
    [QUOTE=Nuclrchiller;15754661]
    QUOTE]
    Any links?
    No links handy at the moment, but a while back I Googled "R404A R507 flooded systems" and got some interesting hits. It seems the low temp guys are already on top of this for replacing R22. I know R404A & R507 will work well at higher temps, but I'd want to get some guidance from DuPont or Genetron before doing anything on a major scale.
  11. #10
    Aug 2009
    Prattville, Alabama
    [QUOTE=icemeister;15754941]
    Thanks icemeister.
  12. #11
    Jul 2000
    Cuenca, Azuay, EC
    [QUOTE=Nuclrchiller;15755311]
    Thanks icemeister.
    Another possibility is to go to R134A if you can stand the 30%+ capacity loss. The small upside to that however is you would gain a bunch of efficiency with the oversized evaporator and condenser.
  13. #12
    May 2013
    Well Guys as I said got the "We'll get Back to you if we come up with something" From Honeywell so it doesnt look good i have two chillers right now in need one is an RTAA Screw that we did switch over to R-422D and Had to tweek some settings to deal with the glide but also may have caused some problems with slide valve so jury is out. Dont think we can afford any major capicity loss so I may have to bite the Bullet and go back with R-22
  14. #13
    If it works for the competition do what they do.
