Results 1 to 7 of 7
    Wireless temperature and Humidity
    Hello,
    We are looking for a wireless stat that supports temperature and humidity. It needs to be either N2 or BACnet/IP.
    Does anyone know of a good product
    THanks
    Northeast
    Viconics makes one.
    Amarillo by mornin'
    Can2Go is BACnet/IP and if you use the Viconics stat with Can2Go, it's easy and quick.
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Quote Originally Posted by xarralu View Post
    Hello, the Can2Go product (temp and Hum stat) is what we are looking for.
    We don't require any type of control, only to read the temp and humidity and pass it via BACnet/IP
    Apr 2013
    Minneapolis, MN
    Some info
    http://cgproducts.johnsoncontrols.co...00668.PDF?x=25
    The above is the standard Wireless sensors JCI offers for Temp/Hum. You need a receiver called a ZFR1800 that plugs into MS/TP bus. (assuming when you say Bacnet you wanted MS/TP)
    http://cgproducts.johnsoncontrols.co...00365.PDF?x=25
    This is the wireless N2 product, but it is only temperature.
    Apr 2013
    Minneapolis, MN
    Ooops just saw your comment on Bacnet IP. Not sure about one of those.... Sorry
