Results 1 to 13 of 20
    May 2012
    Missouri
    air filtration and humidity control in marijuana grow rooms and animal barns
    I have two questions, (or maybe one question for two distinct circumstances) both about IAQ system design and requirements.
    First, has anyone here had any experience setting up a HAVC systems including IAQ elements for pot growing facilities in the "legal" states? I'm in Missouri and a guy I know who used to manage a local parts house moved to Colorado about 18 months ago. he has said there is big money in setting up these places. I was just wondering about the specs for those rooms. I would love to be ahead of the curve when it comes my way.
    Second, I may have the opportunity to bid on a large amount of geothermal work for both the heating and cooling of large animal storage rooms. (barns) The idea is to create a better environment for growing the feed animals. Current technology in the summer is giant fans on one end of the building and giant hole on the other end. so, you have hot animals losing weight and rampant disease. Closing up the building and providing cooling through geothermal may be financially feasible but I don't know about the humidity and air filtration problems.
    so, where is a good place to start learning about high capacity and specialized IAQ systems?
    I dunno, sc will be the last state that "legalizes marijuana" so it probably won't be in my lifetime. I see where that could be a huge new market for hvac though because those are some pricey crops.
    Dec 2009
    Roswell, Georgia
    Personally I wouldn't stoop to that level any more than I would install hvac in a meth lab.
  4. Likes maka liked this post
  5. #4
    May 2011
    Oklahoma
    8th edition manual J has a section about latent load of houseplants. That's where I'd start LOL.
  6. #5
    Madison, WI/Cape Coral, FL
    We do commercial greenhouses. I am sure that could not be anything but legal. The trick is that they need fresh air changes to maintain +400 ppm CO2 levels which is needed for any plant growth. Moisture levels should be <65% to avoid mold. Temps ideal are 75-85^F. It depends on the actual plants grown. A good dehumidifier with fresh air ventilation is part of the system. For more hands on info contact Cliff at Therma-Stor, 800 533 7533.
    Regards TB
  7. #6
    Saint Joseph, MI
    It's just a commercial Greenhouse. Any university with a serious Botany program should have specifications for ideal growth climates. I've even heard of injecting CO2 into the building to increase CO2 levels.
    Consider the climate the building will be in and hte ideal climate for the plants and factor in all heat loads, latent loads, then desing a system to ventilate and dehumidify as needed. Unless it's a dry climate, you'll likely want a chiller for humidty control if you have large fresh air ventilation needs. It will be less maintnace and complex than a specialized dehumidifying AC unit like those used in nanatoriums and spas.
    One other feature you might want to consider for a 4 season climate, is a building with sliding roof panels. I saw this in Norhtern Illnois recently. A hotels pool was indoors, but the center roof panels slid open as well as 1 whole wall being sliding doors. I'm not sure if they plan on using natural light or all artificial lighting.
    Don't forget the heat load from the grow lights. I think you also get some heat form micorbiological activity within the soil.
    Condensate from the air handlers could be collected to water the plants. If in a cold climate, you will want to air wash the glass if using natural light to prevent condensation.
    Again, the most simlar design is that of indoor a pool.
  8. Likes EowBrett liked this post
  9. #7
    Nov 2007
    Quote Originally Posted by bhahvac View Post
    Excuse me but you are comparing weed to meth?
  10. #8
    Delaware
    yeah, that's a bit nuts.
    Always here
  11. #9
    Jun 2016
    good thread
  12. #10
    Jun 2006
    Drugs are not good even aspirin abuse can be bad!
  13. #11
    May 2016
    Loveland, Co
    Quote Originally Posted by cleanair View Post
    I was legit hoping he was being sarcastic with his original comparison comment. Poster, please confirm.
  14. #12
    Dec 2016
    Central Ohio
    The answer for the animals is not a cold floor.... depending on the animal there may be undesirable effects.
    Insulation with plenty of ventilation is the way to go. 2lb density spray foam with a black 6lb density top coat is the best.
    Sent from my SM-N915T using Tapatalk
  15. #13
    Apr 2008
    South New Jersey
    In a pot grow several things are a must Dehumidification is huge, Air Conditioning usually just has to maintain a lowest point of 68F battling a massive Grow light load however the temperature is often changed around to many different settings depending on the strain of plant being produced for harvest. Constant Air movement by way of fans and canister filters are also huge. Basically to calculate Heat Load its comes down to the number and power of lights. Dehumidification Load MUST be proper or massive issues will occur but to figure that you must know how much water will be introduced to each grow room daily estimated. The grow operators should certainly have all the answers to things like that.
  16. Likes EowBrett liked this post
