Results 1 to 7 of 7
    Jun 2012
    502 drop in replacement
    Is 408a a drop in for 502
    LEHIGH VALLEY, PA
    yes 408A is used as a replacement for 502 systems , cant mix the 2 gasses
    Jun 2012
    We have a tech on call and he has has a walkin that is flat with 502 on the txv and no other markings. We are trying to get them up and running tonite
    Jun 2012
    Thanks for the reply hope we can get them going
    Tucson, Az
    Hope it worked out for you.
    If running mineral oil you may run in to an issue.
    Jim
    Tucson, Az
    Keeping the Ice Cream Frozen!
    May 2013
    Utah
    MO-79, R-422A is worth looking into.
    We are having good success with MO-59 for R-22 sub on a similar note.
    Otherwise HP-80 is the best older substitute.
    Jun 2012
    Trouble is having the right jug on the truck. He found the leak on a solenoid valve so he had to go back
