Thread: mini splits
    Feb 2013
    mini splits
    never really had to size a minisplit system. was wondering if it is the same as sizing a normal system or not anyone with any experiance doing this your help would be appreciated.
    Dec 2008
    Ontario Canada
    More or less its the same, due to capacity control, over sizing is not as big of a deal as with conventional splits.
    Air distribution is not quite as good, so multiple heads can be an effective fix for that
    May 2009
    Earth
    I still size them to 100% heat gain and no more, I have had customers that wanted to go bigger, only to find the unit ran a couple degrees warmer then the setting to prevent it from shutting down and ending the dehumidifying process. The right size is always the size to install with any system. I like to sell absolute comfort, not peace of mind that it might not be big enough.
    Arizona
    Quote Originally Posted by Stevel6416 View Post
    Keep in mind there is no duct loss.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
