Results 1 to 13 of 16
    Jul 2000
    Cuenca, Azuay, EC
    Sep 2012
    Quote Originally Posted by icemeister View Post
    What I take away from this..... Nasa ignores refrigerant leaks and just gases and goes to.
    Oct 2011
    Springfield, Missouri
    This leak just might be the one that finally gives Al Gore skin cancer. LMAO.
    Feb 2011
    Peoria, IL
    Use some easy seal, it will be alright!
    Jul 2000
    Cuenca, Azuay, EC
    If you want to watch this cosmic service call live, they're streaming it now, here:
    http://www.npr.org/blogs/thetwo-way/...lk?ft=1&f=1001
    Feb 2011
    Peoria, IL
    Thats awsome!
    Jan 2010
    If he drops a screw with those gloves on it should be no problem finding it.
    Jul 2000
    Cuenca, Azuay, EC
    They're replacing a 13 year old ammonia pump package (which I would relate to replacing a condensing unit) with one of three spare packages available on the space station. It's been installed, no leaks so far and they have just fired it up...all in about an hour ahead of schedule.
    Feb 2011
    Peoria, IL
    sounds like its about (MILLER TIME!) .... or in their case (TANG!)
    Feb 2013
    Lamar, SC
    At least in space it is easy to do a proper evacuation.
    "If you've eliminated all other possibilities whatever remains must be the truth."
    Feb 2011
    Peoria, IL
    Quote Originally Posted by jmsmars1 View Post
    no ozone worry's (ITS one big recovery tank)
    Jul 2000
    Cuenca, Azuay, EC
    Mission accomplished and they're heading back to the barn.
    If you have followed this, they said that these guys have been trained for this replacement procedure and to the credit of all involved...including their excellent tech support in Houston...all went very well.
    It rather makes you appreciate the value of proper training and tech support.
    Jul 2000
    Cuenca, Azuay, EC
    I found it interesting that the original ammonia leakage showed up as "snow-like flakes", drifting off into space from the defective cooling unit. They didn't explain this in any detail, but I would assume the leaking ammonia, as it hit the vacuum of space, flashed to the equivalent of solid NH3...or ammonia dry ice.
    Now as a precaution, theses guys have to hang out in the air lock with the hatch open to "bake off", or sublimate any possible ammonia flakes before re-entering and possibly contaminating the space station with ammonia vapors.
