Results 1 to 8 of 8
    Oct 2006
    Omaha, Nebraska
    Hmm What are the benefits of a Heat Pump?
    I was just wondering what are some of the benefits and downfalls of a heat pump, I dont really work with heat pumps all that much any help would be great! Thanks!
    Florida
    Benefits are more effeciency than electric heat, starting around 3:1 @ 40F ambient and dropping as ambient gets lower. It also compares favorably to gas and oil in areas with low electric cost.
    Negatives are lower supply temps than gas or oil(feels cool to customer if they're used to oil or gas heat), lower life expectancy than straight A/C units, more parts that can go bad(higher repair costs), and cost more upfront than a straight a/c unit. It also loses it's capacity as the temp drops.
    i'm sure there's more.....
    PA/DE area
    We get a BIG discount on electric 6.5 cents per kw V/S 15 cents a KW Oct 15 -May 15 above 600 kw
    It's NOT the BRAND,it's the company that installs it!!!!!
    Feb 2007
    Southern California, LA Metro
    Quote Originally Posted by heatpumpguru View Post
    sounds like you don't need any help in your situation....lol
    Location: I am being held captive by 2 young princesses and a queen
    Larger Duct, Larger Duct, More Air, More Air
    READ THE MANUAL
    What if I train them and they leave?
    What if you Don't train them and they Stay!
    DSG member
    Mar 2006
    tex
    straight electric strip heat should not be used alone. the HP now are superior to the ones 15-20 years ago and normally cost 300 to 500 an will save that much in the first year if not 2. Also with the new energy codes in effect that most installers have ignored for the last 2 years you have to have R8 duct and more insultion than most builders will buy.
    Ky
    Quote Originally Posted by gas1 View Post
    Not sure what you mean by this...what insulation are you talking about? Wall, ceiling, duct, flex?
    LN
    South Jersey
    Quote Originally Posted by climatecontrol View Post
    Low oil bill, high electric bill!
    Not realy the preferred choice north of the Mason Dixon Line, INMHO!
    It Is What It Is
    Ky
    Not realy the preferred choice north of the Mason Dixon Line, INMHO![/QUOTE]
    If only we knew what Mason was charging for Gas and Dixon for Electricity!
    LN
