    Ontario, CANADA
    A/C Unit Filters
    Sometimes there is a Filter that comes with the Carrier condensing unit. Whats it for? Again some guys dont install it and then sometimes they do. why?
    Why are some of the refrigeration lines looped before connected to the A coil?
    Oct 2006
    What????????????????
    Indianapolis, IN
    Dryer. The A/C dryer removes water and some dirt from the refrigerant.
    Everytime system is opened, new dryer should be installed.
    Dec 2006
    if we're talking about air filters, and not dryers, then the reason is going to be that the unit is located close to an opening on the building (and the discharge vent is a very short run) and the filter is added to keep any outside air from blowing back into the discharge if there are no dampers on either the end of the vent, or in the vent by the unit.
    For instance, Im currently stationed in downtown Manhattan, and on some units (usually located on splits where the condener is located near the opening of a louver) filter racks were installed after september 11th, because the amount of dirt and debris in the air (even months later) from the world trade center, and also all the new construction around there. When the unit was off, air would come into the discharge duct and the dirt and debris in the air would clog up the coil.
