Results 1 to 13 of 37
Thread: Contractors
    Sep 2012
    Hebderson Ky
    Contractors
    Found this today. I'm guessing the guy thought he had to have a single pole contactor. Name:  ImageUploadedByTapatalk1368119863.887869.jpg
    Tallahassee, FL
    Yea somepeople actually believe it acts like trickle circuit crankcase heat
    Dec 2012
    columbus, OH
    Quote Originally Posted by SBKold View Post
    I have had 2 teachers tell me this. When I ask were the complete circuit is they get a little jumbled. I just shake my head yes and move on.
    Jul 2009
    Kansas
    Some crankcase heaters work off of single pole contactors.... Also check this out: http://www.achrnews.com/articles/sin...ole-contactors
    Eugene, Oregon
    It's true, some crankcase heaters are wired to single pole contactors. The crankcase heater is wired across the open set of contacts, one lead on the line and the other lead on the load side. Power is from the line side of contacts and through the contactor buss via the compressor windings when the contacts are open. When the contacts close, there is zero potential and the crankcase heater is de-energized.
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Dec 2008
    Ontario Canada
    Quote Originally Posted by Core_d View Post
    I have also been told this by many people, manufacturers included, but never given an actual explanation.
    Eugene, Oregon
    Does not appear crankcase heater is wire to the contactor in this case.
    Dec 2012
    columbus, OH
    The "rumor" is the winding in the motor acts as a CCH. I knew their had to be a little truth to it.
    Aug 2009
    Maine
    Quote Originally Posted by Hwolfe View Post
    Maybe contacts burned off on that side, red neck repair.
    Tallahassee, FL
    There is truth to it but not the way some people imply that simply adding a single pole contractor regardless if it kills common or run and run cap somehow creates heat. It simply does not. Any ammeter will show you that.
    Trane was known in the early days to utilize motor windings as cchtr but they used a distinctly different wiring approach to truly accomplish this.
    May 2013
    Heres a good article to maybe give you some answers:
    Dec 2012
    columbus, OH
    Contractors
    Thank for the link.
    Aug 2001
    Mechanicsville, Virginia
    He used heavy gauge wire to convert 2pole to 1pole. I see no Shame at all. what gives?
