Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 45
  1. #27
    May 2010
    Oxford, UK
    Condenser filled with liquid refrigerant, either overcharged or restriction and condenser too small to hold all refrigerant, and hydrauliced the condenser.
    Had a water chiller evap split and the compressor (copeland semi) pumped enough water to then burst the condenser, mostly blew out the u bends.
  2. #28
    Aug 2012
    Clogged filter drier.
    It's not if your doing it right it's whether your doing the right thing that is important.
  3. #29
    Okieville
    Lightning exit wound.
    Quoted by "bmathews"
    "Just call somebody out. Nobody on here can fix it from over the computer."
  4. #30
    Dec 2012
    columbus, OH
    Quote Originally Posted by Atticmonkey777 View Post
    Electricity travels the perimeter of a conductor.
  5. #31
    Feb 2011
    Peoria, IL
    Is this i question, or a test? do we get to hear the answer if its already known? (I still going with water freezing in bottom of coil, (not sure how that much got there, but i am dying to know, if the answer is known)
  6. #32
    Aug 2012
    NE wisconsin
    Trying to pump 500 ft of lineset into the condensor?
  7. #33
    Jul 2000
    Northern Wisconsin
    AC had quit working late in the summer, super tech came out and added 15#'s of 410A and "kind of" got it working. First time the furnace fired up in the fall and heated up the coil over the furnace the weakest point in the system was the condenser coil and it couldn't take the pressures.
    My really wild guess is the homeowner's best buddy was called when the AC quit working and read on the internet that you could charge them up with propane and they work really good!
  8. #34
    Jan 2011
    Quote Originally Posted by garychance View Post
    I already posted my assumption. The only way for the condenser coil to rupture in 3 places, would be from water. Gas couldn't do that....
    I still don't know the answer. Just an educated guess. Condemned the system...
  9. #35
    Tallahassee, FL
    Quote Originally Posted by jimmyed View Post
    Figured on you "hacking" in and cobbling something together! We've seen you around before
  10. #36
    Virginia
    theres no way it was water
    Have you ever seen water and oil mix ?
    It looks like a vanilla shake
    Compressor would have been long gone before it had a chance to accumulate more than a few drops of water , much less the cup full it would have needed to bust pipes
  11. #37
    Aug 2012
    My official anwser all of the above.
  12. #38
    NJ
    POP!
    I have a theory, lets hear yours.
    I had 3 spots in the lower 2 tubes of this condenser coil blown out like this. I was perplexed by this. I fixed them, just deleted the bottom 2 passes. Turns out I had an indoor coil leak as well.
    25 year old Heil split system, nothing fancy.
    Anyone care to take a guess as to what happened?
    Since it's not a water coil it didn't freeze, my guess is high pressure blew it out
  13. #39
    NJ
