Page 1 of 4 1234 LastLast
Results 1 to 13 of 45
    Jan 2011
    Figure this one out...
    I have a theory, lets hear yours.
    I had 3 spots in the lower 2 tubes of this condenser coil blown out like this. I was perplexed by this. I fixed them, just deleted the bottom 2 passes. Turns out I had an indoor coil leak as well.
    25 year old Heil split system, nothing fancy.
    Anyone care to take a guess as to what happened?
    Feb 2007
    Fremont, Indiana
    Dog piss!
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Mar 2009
    Mid-Mo
    I guess that wasn't too hard to find. Be interested to see what everyone thinks happened...
    Aug 2012
    willowick ,oh
    plugged condenser coil. cracked seam
    SE Michigan
    Moisture in system froze, expanded and blamo!
    Now the freaks are on television, the freaks are in the movies. And its no longer the sideshow, its the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and were dealing only with the freaks. - Jonathan Winters
    Feb 2011
    Peoria, IL
    It froze for sure, with a tear like that
    Tallahassee, FL
    Quote Originally Posted by coolwhip View Post
    In the condenser?
    SE Michigan
    Quote Originally Posted by SBKold View Post
    In the condenser?
    Sure why not?....if there was air in the system, there is moisture. Air can be introduced by a novice just hooking up gauges. What part of the planet do you reside in?
    Tallahassee, FL
    The part where I cant get my head around moisture in a condenser being in the cooling mode filled with warm liquid refrigerant causing said moisture to freeze without upstream restriction.
    Not withstanding the volume of moisture it would take to split a tube from within like that.
    Just my 2c and that's probably about what its worth from some guy on the Internet.
    SE Michigan
    Just a guess on my part. I was thinking this may have been part of a spring inspection in an area that has a winter.
    Feb 2011
    Peoria, IL
    I just know what a freeze split looks like, being a plumber i fix them all winter/spring on water piping
    Aug 2009
    Prattville, Alabama
    Does "nothing fancy" mean no high pressure switch?
    Jan 2013
    Frederick, MD
    Just a weak spot. Finally gave out. If nothing else was found I would not over think the problem.
