    need help? question
    5.what is the purpose of the time delay relay on
    > air conditioning?
    > a.fan to start before the compressor
    > b.to help maintne even temp in dewelling
    > c.grankcase warm up to starting
    what is the answer? thanks
    Kentucky, Michigan, Ohio, Arizona, Colorado, Nevada, and Califormia
    More info. What time delay ? Outdoor unit time delay ? indoor unit fan delay ?
    Outdoor time delay is to prevent short cycling/hard starting of the compressor. Indoor time delay (fan) is for efficiency and comfort. It allows the coil to become conditioned before air movement. You're a professional member ?
    "Surprised ?! If I woke up tomorrow with my head sewn to the carpet, I wouldn't be more surprised."
    Clark Griswold
    I need help?
    what is the answer?below
    1・What size of drian pan is requed on propan system?
    a.3 inch high 3 inch large then equitesment
    b.3 inch high same size as eguitment
    c.1 inch high 3 inch large then equittment
    d.1 inch high same size as equitment
    2.what is the purpose of the time delay relay on
    air conditioning?
    Jul 2002
    Yuma, AZ
    1. c
    2. d (none of the above)
    3. Why?
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Quote Originally Posted by lynn comstock View Post
    1. c
    3. Why?
    thanks
    Dec 2006
    New Jersey
    a time delay is to prevent your system from being turned on before its pressures equalize. prevents the homeowner when playing with there tstat from turning it on, off, on
