Results 1 to 13 of 22
    Mar 2009
    East Rochester, NY
    Trane Compressor Leak...Is it fixable?
    Hi all,
    We have a Trane CGWD050GCONT101 Chiller in our building. One of the two circuits is down at the moment, as the 15 ton compressor (Model CSHS150J0HOF) has a rather large leak on the suction fitting, which is pretty rusty. My question is this: Is it possible to repair just the suction fitting? All the quotes we have received so far have been to replace the entire compressor, at a very large expense. I just want to know if it is even possible to repair it, as that seems like it would cost less than replacing the whole (otherwise perfectly good) compressor. The model they have quoted for replacement is a CSHA150R0*00. I have also received a quote for a Danfoss at about 2/3rds the price.
    Thanks in advance for your advice!
    -Mike
    Ya don't want to go cheap on this one.
    Mar 2009
    East Rochester, NY
    That's what I thought, but I need to convince the guy that pays the bills Any good arguments for why a hermetic compressor cannot be repaired? My thoughts would be that there isn't an easy way to do it that I can see that wouldn't result in metal shavings or welding spatter ending up inside the shell...
    The other option one of our quotes gave was to remove that compressor, cap off it's connections, and run it with 3 compressors instead of four. Would that be a reasonable temporary fix to get us through this season, until we can afford to replace that compressor?
    MEXICO
    need to change the compressor!
    Quote Originally Posted by Driverfound View Post
    Hi all,
    -Mike
    Can you post pictures of leak location?
    Mar 2009
    East Rochester, NY
    I'll go get some pictures on my way out, and post them tonight...It seems to be a pinhole type leak on the underside of the suction fitting on the compressor...It was pretty badly rusted. My other concern is what shape the other three compressors are in if that one was so bad.
    Apr 2009
    Rio Vista CA.
    servicetech
    Please check your PMs.
    Thanks, AOPC
    DeltaTech
    Mar 2009
    East Rochester, NY
    Here are some pictures of the leak area on Compressor 'C.' The leak itself is on the underside of this fitting, right smack in the middle.
Size:  19.0 KBName:  compressor2.jpg
    The Hot South
    I don't see any way to repair that without replacing the compressor. The steel is too rusty. If by chance someone was able to stop the leak, don't expect the repair to last long. R22 is too expensive to be messing around with this. If I was the tech looking at this, compressor replacement would be the only option I would give you.
    MEXICO
    there is really no other option, replace the compressor
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by R123 View Post
    Reading this thread, I was on the fence, waiting for pics. Not any more. The reminder of R22 prices is the ol' nail in the coffin.
