Hi
Top Discharge outdoor condensing unit 180k Btu/hr installing in a enclosed mechanical room and connnecting d duct to exhaust hot air outside the building. Is this work with axial flow propeller type fan
Not excluding the massive amount of regarding this post..
But:
What is D Duct?d duct
Is that similar to "B-Vent"?
Isn't axial type fan d kind blows air upward not outward?
What size d duct? Any booster fans installing?
Did you skip d grammar classes? Take d ritalin and call in d morning.
Hi nd, and could i welcome you and ask if you could include an exhaust fan in the duct work on aux contacts with the cooling? or d cooling? We do not use auxiliary fans at all with smaller units doing the same thing, but it probably would require a certain size duct, and I am not d man for d job.
It's great to be alive and pumping oxygen!
Cdb? Ma no B! Osar! Cm? Well I'll B!
According to TABB ( Sheet Metal and Air Conditioning Industry) a propeller fan should not be connected to any duct work because the resistance of the duct increaces fan BHP unlike a centrifugal type fan.
I have installed a temperture controlled exhaust fan that kept a room cool and let the condensers run normally.
We are here on Earth to fart around ......Kurt Vonnegut
You can be anything you want......As long as you don't suck at it.
USAF 98 Bomb Wing 1960-66 SMW Lu49
