Results 1 to 13 of 30
    Sep 2010
    miami,fl.
    supco hard start kits
    I don't know the exact part numbers but supco makes these little hard start kits 1/4-1/3 hp and 1/2hp. power your 110 vac through the 2 blacks and common is black start is white and run is red. for small reach in compressors. ive used them for years works good but recently the last 2 that I used was the 1/4-1/3 hp for a 1/3 hp compressor. compressor is amping within compressors name plate rla. but overload in hard start kit still overloads after running for about 5 mins monitor amps they don't spike up or nothing odd like that, no my voltage doesn't drop out of no where. I feel since its a 1/4 - 1/3 and its a 1/3rd hp comp. its on the high end and the overload is not strong enough. ive bypassed overload in the kit to make sure compressor runs good and it does. I think these things should have an amp rating along with hp rating. im going to find a supco tech support number and call ato find out whats the rla max for these start kits but im wondering if others run into this issue or do they know the answer to my question??????????????
    Apr 2003
    Maple Grove, MN
    What you are looking for is a RCO210. It is good for 1/2 horsepower or 13.3 RLA. What you have in there now sounds like a RCO410, which is rated for 7.5 amps. You can find this info on page 58 of Supco's catalog.
    http://www.supco.com/images/pdfs/200...0for%20Web.pdf
    Jul 2011
    Lehigh Valley, PA
    Why are you calling this a hard start kit? Isn't this part simply a replacement for the OE start kit? I thought a hard start kit would add a start cap into the circuit along with the OE parts.
    NH
    Start cap is built into it... I believe.
    Jul 2011
    Nanaimo,BC, Canada!
    I had this same problem yesterday with a 1/3 hp supco 3 in one start kit. I narrowed the problem down to the ambient temp around the condensing unit being too high.. 95 f .. Got the space temp down to 75 and wouldn't you know the unit works fine now..
    Dec 2006
    In a Mess
    imagine that!
    Sig removed by mod. G-Rated site
    Mar 2002
    fort walton beach fl.
    Was that 1/3hp compressor a AEA440YXA? I had contacted supco before about this model number compressor and using the 1/4 to 1/3 3 in 1. They told me to use the 1/2hp 3 in1 for that compressor. Been doing it ever since and haven't had any problems.
    http://acfwb.com/
    "The best preparation for good work tomorrow is to do good work today"
    Had same problem. Solution was to stock tecumseh 1/4 and 1/3 hp relays and overloads in vans(aea4440 and 4430 are the most common compressor to run into) and use 3 in 1 until we could get factory start components for other brands/hp compressors.
    Sep 2010
    miami,fl.
    I appreciate everyones replies to my post. the compressor I was working on the other day was an AE4440YS yes I typed it right. it was my first time seeing this model the guy at the local supply house kept telling me im wrong lol until I told him to look it up!
    Sep 2010
    miami,fl.
    Quote Originally Posted by Capz View Post
    I guees im used to calling them hard start kits, but yeah they have a start cap built in but that doesn't give me the right to call it a hard start kit because the unit in normal conditions has a start capacitor so yeah I should be calling it a start kit. ima read the package to see the actual name just curious.
    Yakima, WA
    The brand name is 3-in-1, but then Freon is a brand name too. I followed your train of thought with hard-start kit. I suppose you could say self-contained-universal-starting-component-accessory-with-inherent-thermal-overload-protection, but I'll probably stick with 3-in-1.
    Dec 2006
    In a Mess
    Cool Nomenclature!!
    Quote Originally Posted by ammoniadog View Post
    What you are looking for is a RCO-210.
    RelayCapacitorOverload-210.
    Dec 2012
    Illinois
    In my past in the residential appliance world we called that a "dynamite stick" because they were guaranteed to "blow up" your compressor. But that's putting a 1/4 hp kit on like a 1/20th hp compressor. Residential don't have start capacitors, they have run caps sometimes but no starts.
    This could be the start of a great discussion.
