Results 1 to 13 of 16
    Feb 2007
    Telephone Controlled Thermostat
    I am considering getting this telephone controlled thermostat for my beach home.
    I was wondering if anyone had any experience with such a device. I would find it helpful to be able to have the heat or AC come one prior to my arrival by calling into the thermostat and having the temperature set to a comfortable level. I assume that I will have to run another 2 conductor wire behind the wall to the thermostat to connect to the phone line.
    Any comments or suggestions is appreciated. Thanks.
    Jan 2006
    I service several beach homes(in Florida) that have this type of control for multi unit installs. Not as simple as running a phone line. I have seen 3 or 4 different systems, most work well if wired properly. Usually the controls are installed by alarm people. Most of us(HVAC Contractors) don't install these, license and insurance conflicts. Make sure you give your HVAC servicer override codes.
    Mar 2006
    Delaware
    I have this one on my beach place, and love it:
    http://www.scillc.com/cem%20series.htm
    Upside, inexpensive and works well.
    Downside, only one zone.
    Feb 2007
    Lexington, Kentucky
    Better get a qualified telephone repair serviceman to put that in for you.
    Mar 2006
    Delaware
    The telephone connection is utterly a piece of cake. That's not should worry most installers. It's the connection to the HVAC equipment that'll get you in trouble!
    I've considered getting one for my beach house
    BUT
    I'm not that sorry, YET, that I can't wait until I get there to turn it to a more comfortable setting.
    NO...........I never turn the system off.
    Mar 2006
    Delaware
    Neither do I, but it's sure nice to have it at the right temperature when I get there, and to be able to call it up to make sure it's still working, and the temperature is where it belongs. Especially in the winter, THIS winter!
    Quote Originally Posted by dandyme View Post
    BUT
    Feb 2007
    Quote Originally Posted by kuryakin View Post
    That was the thermostat that I was considering. I see that it need a 24v common wire. The existing thermostat only has four wires. I assume I need to run another wire from the furnance to the thermostat for the 24volt. If this is so maybe it would be best to get an HVAC contractor involved.
    Nov 2002
    Boiling Springs, SC
    Beach House
    Check in to the Honeywell IAQ Thermostat. It is a touch screen thermostat with alot of wonderful options.
    Mar 2006
    Delaware
    Quote Originally Posted by fixer View Post
    Does it come with a telephone feature?
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    These are great! I have installed tons of them in beach and summer homes. Easy to install, any hvac contractor should be able to take care of you for a small charge. Buy your own stat and have a company install it.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Nov 2002
    Boiling Springs, SC
    phone access
    Yes the Honeywell Vision Pro IAQ Thermostat can be connected with the phone access module. Check out www.customer.honeywell.com and click on the Vision Pro IAQ Thermostat. Alot of great information on the thermostat also you can download manuals on the thermostat there.
    Nov 2002
    Boiling Springs, SC
    Redtundra,
    The Honeywell Vision Pro IAQ Thermostat Operates with just 3 wires. This thermostat communicates with a control panel that runs the system.
