    Filter in Return with Aprilaire 2200
    I had an Aprilaire 2200 installed in my new Rheem Central air system. I was told not to put a filter in the return grill b/c it would cause to much restriction. The only problem is you can see the sheetmetal and flex duct. Is there something i can put in the air filter space to restrict the view but not cause air restriction. Thanks.
    S.W. PA
    turn system off, paint sheet metal black, let dry, turn system back on wont be perfect but will help some
    SW, Michigan
    agreed: flat black spray paint (WITH THE UNIT OFF!)
    GOD knows if you did your best! <><
