Results 1 to 9 of 9
    Jul 2013
    ZN341V+ wrong driver issue
    Hi Guys,
    I am getting "Wrong Driver" error while setting up ZN341V+ with WebCtrl 5.5. Modstat report shows:
    Does anyone have updated driver for this?
    I formatted the controller several times and tried to load the driver I have from my server but then I got "Communication Failure" error.
    Then out of frustration I formatted one of the 341v+ with address dials at 0,0. Now I am getting this:
    Can this be brought to life again? The error light is on and the run light is flashing rapidly. I think the manual says that means it's in Boot Mode.
    Jul 2013
    Here are the images again:
    Jul 2013
    This one is after I formatted with address dial at 0,0.
    Sep 2013
    Milwaukee, WI
    Do you have access to the ALC website? They started shipping the controllers after a certain serial number that needed a specific new driver from the site, rather than just the standard ZNPlus driver from earlier releases. I worked with ALC for almost 15 years and never bricked a controller, no matter how hard I tried. You might just need this updated driver (of which I no longer have access). Good luck!
    "The problem with internet quotes is that you cant always depend on their accuracy" -Abraham Lincoln, 1864
    May 2009
    Seconded, I ran into this as well. The new ZN modules are shipping with updated hardware which requires a 6.xx.xxx module driver.
    Basically the stance of ALC is always use the latest module driver available. According to them it isn't a problem to use a 6.xx.xxx driver in older versions of WebCTRL either so even if you are on 4.1 you can use whatever the newest driver they post is.
    Scott Jalbert
    WebCTRL ninja
    AX and Smartstruxure newb
    The S in IoT stands for Security
    Jul 2013
    Quote Originally Posted by MaxBurn View Post
    I don't have access to their website. Do you have the latest driver?
    Sep 2013
    Milwaukee, WI
    I'll see if I can procure it.
    Apr 2014
    MN
    Quote Originally Posted by DWuthrich View Post
    You obviously weren't trying hard enough. Remember how to brick a ME-LGR?
    Apr 2014
    MN
    Send me an email and I'll pass it along.
