Results 1 to 12 of 12
    Jun 2011
    MN
    How do you find technical specs online?
    So my buddy who is on call this weekend calls me fifteen minutes ago.
    "What temp are fans supposed to come on in a walk in freezer?"
    "I guess zero to ten is pretty good." I'm still a rookie...I still have to look up specs. "I think the part number should give you some sort of clue, shouldn't it?"
    "Yeah, usually, but I can't tell on this one."
    "What's the number? I'm sitting in the living room, I'll google it."
    "20425d56-520-b10,"
    I type it in and go into google warp. I modify the search by adding the word "temperature" then "fan delay." It got worse. I told him I could order him one for $25 but I had not idea what what the specs were. How do you find this stuff out?
    Mar 2013
    fans should come on after a defrost at around twenty degree coil temp i believe,
    Mar 2009
    Mid-Mo
    20-25 are mostly what I see. When using google it's easier to search the model number, find the IOM, then find the info in there.
    California
    Quote Originally Posted by cswenson218 View Post
    I find my specs with google searches.
    It's just, that takes experience too!
    what you need is...more experience...keep it up!
    Dec 2012
    columbus, OH
    I would type in brand name then module #.
    Yakima, WA
    Doesn't answer your original question, but evap fans will never start while you stand there and watch them. After the system runs for a while, and right at the point where you want to get your screwdriver and meter back out, go out to the van, have a smoke or start filling out your invoice. When you come back in they'll be running.
    Phoenix,AZ
    Isn't it printed on the side of the klixon? Like 20f and 55?
    Jun 2011
    MN
    LOL...that is what I wish I would have told him, cjpwalker.
    Jun 2011
    MN
    That's what I told him to check. They were either not there or not readable...hence the google fiasco. I even thought the part number contained that info.
    Jul 2000
    Guayaquil, EC
    I entered your number into Google and within the first couple of results I found that it's a Heatcraft/Bohn part # 5709L.
    Do a new search on that P/N and quickly find that it opens at 55ºF and closes at 35ºF
    Usually when I'm looking for a part number or info on a part, I'll start with the unit model number, as was mentioned.
    cyberspace, FL.
    Experience, and this site really helps guide You in the right direction, keep up the learning!
    sent from my dumb ass verizon upgrade.
    Jun 2011
    Decatur, IL
    Manufacture website is always the best place
