Page 1 of 9 12345678 ... LastLast
Results 1 to 13 of 106
Thread: New ak set-up
    Feb 2007
    Fremont, Indiana
    New ak set-up
    Noticed that my AK manifold is leaking by last week, and doesn't seem to be any adjustment left. Being that they're 3yrs old, I decided to order the revolver to slap under them.
    I'll probably order a rebuild for the DC manifold anyways, so if I don't like the new set up I can switch back. However, if indeed I do like the set up, I will keep the DC manifold in service with standard gauges attached.
    Wish me luck!
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Good luck
    Tallahassee, FL
    What adjustment is available? I just got a AK900 and curious.
    Feb 2007
    Fremont, Indiana
    The reason I picked the revolver is the ball valve feature which resembles the DC, and I absolutely love the 1/4 turn. With the added bonus of the four hose (for those lazy days).
    The adjustments are on the side. Adjusted with an allen wrench.
    Saturday I noticed my low side leaking by when charging a wi freezer, I adjusted it all the way in to no avail. High side leaking by too, same results.
    With as much use and abuse as I've given them, I am in no way dissatisfied with the DC manifold. They will be rebuilt if that option is available! But in the meantime, the revolver will get a shot!
    A Einstein
    Feb 2007
    Fremont, Indiana
    Good luck
    Personal experience with the revolver?
    A Einstein
    Just wishing you good luck like you asked for
    Jan 2013
    Isn't the Revolver a Sherman made by thermal?
    I was looking into one and the Thermal site said "discontinued". So I got a YJ instead. Don't want to be stuck with a manifold with no replacement parts.
    If you know something different let me know.
    Atlanta GA area
    Quote Originally Posted by hvac5646 View Post
    I am about to order an AK... probably without the manifold. I prefer using a 4 valver also... Would be interested in results of the 'revolver' also.
    I do not like using the offsets... so there are only a few manifolds that will work. I would like to get away from the Titan-2... valves are too stiff.
    Thoughts and suggestions?
    GA-HVAC-Tech
    Jan 2013
    Quote Originally Posted by ga-hvac-tech View Post
    Any manifold can be stiff, but does not mean its bad.
    Atlanta GA area
    The DC1250 I have used for 6+ years has a Titan-2 under it. The valves are too stiff... not that I cannot turn them... just would be nice if the valves were not as stiff.
    Now a question for you: Why NOT shop around for a better manifold? As far as the gauge set... I believe for me the DC is the better choice... The manifold question is still open.
    GA-HVAC-Tech
    Jan 2013
    i don't understand.
    Tallahassee, FL
    Forgive my ignorance I didn't see anything about adjustment in manual.
    What do the Allen screws do or what adjustment are they making?
    May 2011
    Western, KY
    It's branded JB, doesn't look like the Sherman, if I'm thinking of the same manifold you are.
    http://jbind.com/products/product-se...aspx?SKU=26040
