Thread: Scotsman SCE170
    Nov 2009
    Scotsman SCE170
    Looking for the test procedure for the bin switch on an SCE170A1C. The curtain magnet is good and lined up with the switch. Looking for info on testing the switch and the controller.
    Mike
    Phoenix,AZ
    use a ohmmeter or look at the lights.
    Nov 2009
    Thanks for the input.
    I should have been more detailed in t he 1st post. Both lights are out. The switch is 4 wire, low voltage DC. Not sure which 2 wires will keep the machine from starting. Also, there is a visible hot spot on the control. I've been searching the Scotsman website but no detail on this circuit. I would think there is a procedure for testing both parts.
