Results 1 to 2 of 2
    May 2013
    SEER 13 vs SEER 16 2-stage condenser?
    I live in Southern California, San Fernando Valley, zipcode 91352. I am getting a AC split system installed on Monday in a house that has no AC at this time. What I need help with is this, do I go with a SEER 13 basic system, or do I pay $ more for a SEER 16 2-stage condenser. I get $300 tax credit and $300 from DWP(local power company)if I get the 16. Do you think I will be able to get my $ back threw the energy savings of a SEER16 2-stage system?
    I both would be Goodman 3 ton systems.
    At my last residence in a cando I used about $350 worth of electricity a year @ about $0.12 per kwh but I'm not sure what size system and seer system I had, but the condenser was replaced 2010.
    May 2012
    San Diego, CA
    California Energy Codes say minimum 13 SEER for your original 2010 condenser. SEER is cooling capacity divided by watts of power used, so a 16 SEER should theoretically use 23% less electricity than a standard 13 SEER (~$80 savings). 2 stage is also great when you have more mild day and you don't need all 3 tons.
    Now, you are changing out the furnace too right? The manufacturer tests their condensers and furnace combos to get that SEER rating... so a highly efficient condenser won't be as efficient if the furnace fan draws a lot of electricity.
    You can call me Sam
    It should be a crime to be a mechanical engineer in San Diego
    Summer Design Temperature: 83 F Dry Bulb ~ 69 F Wet Bulb (California Climate Zone 7)
