    2 Stage Heat Pump VS Regular Heat Pump and Variable Speed Air Handler
    Would there be enough difference in cost savings ( operating costs ) to justify a 2 stage heat pump vs a regular heat pump with a variable speed air handler if both were the same approx. seer and hpf?
    The difference in cost of the units is approx. $ 1,500.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by wscsteve View Post
    Would there be enough difference in cost savings ( operating costs ) to justify a 2 stage heat pump vs a regular heat pump with a variable speed air handler if both were the same approx. seer and hpf?The difference in cost of the units is approx.$ 1,500.
    if all you are worrying about is justifying cost you will never be happy,
    but as far as comfort and humidity removal you cant beat the 2 speed!
    PA/DE area
    If tax credit unit,it is less than that add in that REBATES start in March so,if your staying get it.AWESOME COMFORT!!!
    It's NOT the BRAND,it's the company that installs it!!!!!
    Lancaster PA
    If they are the same SEER, and HSPF, then one won't save you money over the other.
    Some people do set their thermostat a degree or 2 warmer in the summer with 2 stage units because of the better humidity removal. So you could see a small savings, but not enough to recover that much of a cost difference, in the life span of the unit.
    2 stage is for comfort.
