Results 1 to 7 of 7
    Jun 2012
    Northeast
    10K ohm resistor chart
    Anyone hve a pdf. of the temperature to resistance values for the standard 10K resistor? I am working on a Trane IntilliPak M# SCWGN3543.....
    IOM does not have the chart for checking their evaporator temp sensors.
    Jun 2006
    New Jersey
    Hears a couple of docs I use alot. It normally gets me through 90% of sensors out there.
    RTD-Thermistor_Z202030-0N.pdf
    Sensor Cheat Sheet.pdf
    NEW JERSEY
    Just Google 10k thermistor chart.
    SE Pennsylvania
    Here is the Trane chart from the manual, page 82.
    https://dl.dropboxusercontent.com/u/...tanceChart.pdf
    May 2002
    Baton Rouge, Louisiana
    Heres the one I use from ACI
    thertempcurve.pdf
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Feb 2013
    Phoenix, AZ
    The tables imply it, but no one has mentioned it, there are two common 10K RTD's - type II and type III, best to use the table that matches your particular sensor. acsj's table lists them both.
    Jun 2012
    Northeast
    Thaks for the help Guys. It was nice to find out that there are two type.When I contacted Trane tech support they said to use any chart for a 10K ohm resistor, they never mentioned there are two types
    hvac69 I am going to have to look through the Trane IOM again. I swear I did not see that page.
