Thread: Gas valves
    Feb 2007
    Gas valves
    I just wanted to clear up some gas valve terminology.
    What does it mean when they call a valve Redundant?
    thanks.
    east central indiana
    It means it has two valve inside it. In case one fails.
    41530 is right and correct too.
    Believe none of what you hear and half of what you see.
    Feb 2007
    so it just means there is a pilot valve and a main valve?
    When there is a pilot valve and main valve in the same valve body, it is called 'combination'. 'Redundant' is a fail-safe feature. There can be a 'Redundant combination' gas valve.
