    Jul 2012
    Considering 2 new replacement Systems (2.5 ton AC/60-70K BTU 80% AFUE Furnace/Coil)
    Hello,
    I am considering the following 2 systems: (All systems referenced have been properly sized)
    Trane:
    Condensor: XB-14 (4TTB4030E) 2.5 Ton (Up to 16.5 Seer)
    Furnace: XT-80 (TUD1B060A9H31B) (60K BTU 80% ACFU)
    COIL: TRANE 4TXCC044BC3
    April Aire System Installed
    Looking at this Easy to Use Thermostat (Emerson 1F95EZ-0671)
    The Furnace is only 17.5" Wide but the coils are 21" to get to the 16 SEER Level for Tax Credit (AHRI 3442927) My question is can a 21 inch coil be used on a 17.5" furnace?
    Is this Trane System a good basic setup?
    The 2nd system is a Carrier System
    Condensor: Carrier Performance Series 16 (24ACC630A**30) 2.5 Ton (Up to 16 Seer)
    Furnace: Performance Boost 80 Furnace (58PHA070-16 66K BTU)
    COIL: CNPH*3117A**
    April Aire filter installed
    Any opinions about either system would be apprciated
    May 2013
    Southern Maryland
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Mr. Return, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
