Results 1 to 2 of 2
    Jul 2011
    Metasys BAS Server-HELP
    Dear Sir,
    Why would you not load the software for graphics, help menu and CCT not on the BAS server, and on the workstation instead or laptop only? Would that be done due to the server is undersized? If so, what about an upgrade?
    Reasoning pro and cons for doing this?
    Thank you,
    Apr 2012
    What software version are you running
    Lon or BAS
    Usually all files are on the server and the workstation will access the system through the server. The files on the work station are usualy data base back up files. The software service tools are on the laptop.
