Results 1 to 12 of 12
Thread: The Heat Pump Blues!!!!
02-18-2007, 08:15 PM #1
- Nov 2006
- New Boston, TX
- 282
Ruud HP, will work in cool, but in heat the true suction shows to be pulling down into a vaccum, what is the deal...lost in texas?
02-18-2007, 08:27 PM #2
- Sep 2006
- erwin nc
- 86
metering device in outdoor unit clogged.
02-18-2007, 08:36 PM #3
- Nov 2006
- New Boston, TX
- 282
How did you come to that conclusion, please explain
02-18-2007, 08:38 PM #4
is it a new unit??
WORK HARDER!!!!! millions on welfare depend on you...
opinions are like bungholes everbody has one...
02-18-2007, 08:40 PM #5
- Nov 2006
- New Boston, TX
- 282
no, its an older unit
but its got a txv on the indoor coil
02-18-2007, 08:45 PM #6
what about the outside unit does it have a txv too.
02-18-2007, 08:49 PM #7
- Sep 2006
- erwin nc
- 86
i installed hundreds of the ruud split heat pumps from early 90s to present, and with that symptom that was the first thing i would check, in the heating mode the metering device on the o/d unit is the one that meters and if there is no flow ( restriction ) unit will pull down in vacuum, the reason it works in cooling is that the txv on the indoor coil meters in the cooling mode, hope this helps.
02-18-2007, 09:52 PM #8
- Nov 2006
- New Boston, TX
- 282
the outdoor unit looks like it has a distributor and a txv whats up with that
02-18-2007, 09:55 PM #9
Banned
- Oct 2003
- Washington
- 7,405
02-18-2007, 10:13 PM #10
- Nov 2006
- New Boston, TX
- 282
seaton you are an ass.....im just asking a question...
02-19-2007, 12:15 AM #11
Banned
- Oct 2003
- Washington
- 7,405
02-19-2007, 05:14 AM #12
