Results 1 to 10 of 10
Thread: 410 a leaks
    Feb 2013
    richmond va
    410 a leaks
    anyone having trouble finding leaks in residential 410a equipment I use an h10 I was told it was designed for refrigerants with chlorine and to turn up the diode
    Jan 2010
    Sea to Sky
    No trouble here. I use the medium setting for R-22 and the low setting for HFC's. What my manual says to do and I find it works.
    Jun 2006
    SW MO.
    We resorted to using dye.
    We're awl pawthetic and kweepy and can't get giwrls. That's why we fight wobots.
    Jul 2012
    Western KY
    Quote Originally Posted by chaard View Post
    Jan 2013
    New Jersey
    9 times out of 10 I found the leaks mid-section of the evaporator coil when it's a 410a system. Especially a Lennox coil.
    Mar 2012
    The new field piece is great for 410
    May 2013
    I have found the Amprobe UltraSonic to be very good for finding leaks in coils.
    Dec 2001
    Harnett County, NC
    I bought a cheap CPS detector and it works great on 410 but not so good on 22
    Aug 2011
    McKinney, Texas
    410a was specifically designed to be higher in pressure to environmentally safe, as opposed to R22. Now after stating the obvious, the reason there are so many more leaks in 410a systems is because of a design flaw that many manufacturer's didn't see coming. A condensating coil, such as an evap coil, with R410a running through copper tubing eats the copper away. THEN! The best part happens, the water mixes with the refrigerant and causes acidic properties that harm many known metals. It's pretty crazy but most brands have moved to aluminum evap coils. Or better yet, aluminum painted copper coils. lol
    Aug 2011
    McKinney, Texas
    I side tracked. My answer would be the good, old fashioned, soap and bubbles. I have found some leaks I would have completely overlooked without it. Messy but very successful.
