Results 1 to 13 of 15
    Apr 2013
    Hudson Valley New York
    High Performance Home with fireplace issue
    I have a homeowner with a problem when burning his fireplaces with the doors open. The fireplace does not smoke at the opening, but odors are being drawn in at the conditioned attic. The house is tight, although no blower door test done.
    Some of the odors are smoke related, but the smoke alarms do not go off. Some of the odors are sewer gas. The appear about an hour after the fireplace is used.
    I advised the homeowner to open a window when burning the fireplace to see if this eliminates the smells. Assuming it does, is there anything other than opening a window that will work?
    Dec 2011
    We need more information to help you, Is it a wood fireplace or gas fireplace? if gas is it vented?
    Apr 2013
    It is a wood burning fireplace. One is a factory built unit and one is field built.
    Dec 2011
    You are very confusing with your plurals. There are two separate fireplaces, do they both vent into same chimney/chase and do they have separate flues?
    Apr 2013
    2 fireplaces. 2 chimneys. Both chimneys inside thermal envelope. Separate locations in house. Both on first floor
    Dec 2011
    Will either one cause odors in the attic?or is it one specific one that causes the odor? You say the attic is conditioned, I'm assuming it is unfinished and unvented. Are you only smelling it in the attic? How old are the chimneys? have they ever had a chimney fire? If opening a windows doesn't help, it could be cracked flue liners leaking into the attic. You should probably have the chimneys get a level two inspection. If opening the window does help, they need to have fresh air brought in to the fireplaces.
    Apr 2013
    Both create smells. This is a new construction and no more than a few fires built. Both have outside air, with ducts not crushed.
    It has been suggested to check for small amounts of smoke escaping from the top of the fireplace opening.
    What I suspect is with the doors open there is not enough free air to properly vent the fireplaces.
    The question is; if opening the window works, what is the best way to remedy the situation?
    Atlanta GA area
    Building a house 'tight' is great for lowering heating and cooling costs... however fireplaces that do not draft properly is one of many results of a 'too tight' house. Other issues include a clothes dryer that does not dry well, kitchen hood that does not take out odors, bath vents that do not take out odors and do not lower humidity... See the pattern: not enough air coming in to replace the air going out. In the industry we call this Make Up Air or MUA. Another issue of a 'too thight' house is the air gets 'stale'... which is a health hazard.
    Have an energy specialist come out (preferably one that is also a fireplace specialist), and look over the house. I suspect you will find two things:
    1) Something wrong with the fireplaces and/or flues
    2) House is too tight and needs more MUA
    Correct these issues and you will be fine.
    As to specifics; well someone needs to be there to inspect the house...
    GA-HVAC-Tech
    Apr 2013
    GA-HVAC Tech
    Nothing wrong with the flues. I know the house is tight and all that. The question is about solutions. What methods are there to make the open fireplace work with open doors in a tight house, short of opening windows.
    By the way there is no such thing as a too tight house. Just improperly vented houses. There are 2 HRVs installed for ventilation and the kitchen hood has an interlinked fresh air vent with damper. The dryer has a boost fan. The baths are naturally vented through the HRVs. The question is how to make the fireplace work.
    Atlanta GA area
    I already answered your question: Either the fireplaces and/or flues are not right, or there is not enough MUA.
    However it seems engineering principles are more important than what works and what does not. If I had a nickel for eery time I have seen this thinking... I could retire.
    I will wish you the best of luck...
    Let us know what you figure out.
    BTW: Behind the Pro door at this forum is a building science forum (for professionals only). If you had access, you would be able to read many a well certified person with years (some decades) of experience--explain that YES, a house CAN be 'too tight'.
    GA-HVAC-Tech
    Apr 2013
    I posted here because I was told there was possible resident knowledge here.
    I got actual help on the building performance linked in site.
    You would do better to spend more time reading about building science, and learn why there is no such thing as a too tight house, than promoting the behind the curtain professionals.
    I am an HVAC professional and have been for over 30 years, I just did not bother to take the time or effort to get behind your curtain. Good luck, you should pray more and give advice less.
    Madison, WI/Cape Coral, FL
    How much fresh air ventilation is provided? I suggest that you have a minimum of a fresh air change in 4-5 hours minimum. This should be fan powered. Bathfans, kitchen hood, and clothes drier may need more. Open combustion devices using gravity chiminies compete with each other and all the power exhaust in the home. Wind also creates negative air pressure that may back draft them.
    Consider a whole house ventilating dehumidifier like an Ultra-Aire with a make-up air ventilation option for you fresh make-up air source.
    Supplemental humidification and dehumidification may be need depending on the outdoor dew points and the number of occupants in the home.
    Regards Ken
    Atlanta GA area
    Quote Originally Posted by Lloyd H View Post
    Please do not take this personally... however someone seems to come along about once a month...
    They are always a 'guest'... not a Pro. They seem to think they know more than the PRO's here... and act 'superior'.
    They usually leave without much information because of their behavior.
    I will stand with my diagnosis in post #8...
    Please let us know what you find, and what the solution is.
    GA-HVAC-Tech
